ControlLogix processors Software download date and time
Switek
Nov 2008
Cork/Ireland
25
Hi all,
Does anyone know if how I can get software download date and time from the ControlLogix processors (1756-L62)? That would be great if I can read date and time of last modification in the software - if done online.
I tought about using GSV, but anyone knows the classes I can use? Or where I can find them?
I am using RSLogix 5000 v.16
Thanks,
Switek
The only thing i can think of is to use s:fs to trigger a GSV instruction to store the current date. That wouldnt help you track online changes though.
Good idea!!! Thanks, the simple solution is the best solution. :)
But if the software change will remove this rung - I can not show the download date. I would like to do it much more dependant from hardware. If possible.
Regards
Pawel
Version 17 firmware has a feature where changes during runtime are logged to the CompactFlash card and the times are accessible with GSV instructions.
This feature is described in detail in a Programming Manual, publication 1756-PM015.
If you're looking for a powerful change logging, archiving, and disaster recovery system, FactoryTalk AssetCentre is the way to go. But for simple logging and occasional sleuthing, the runtime change logs can do the trick.
Hi Guys, Is it okay to have Redundancy ControlLogix Processor IP address set to DHCP? I had Static IP address on it but removed it via RSLinx...
252
Hey everyone, I feel like this is an easy question, but I can't seem to find an answer for it. Currently have a PLC-5 that we're swapping out...
1,843
I just wanted to warn everyone that, according to Rockwell, standard PanelViews, 2711-WXYZ, can't communicate to an 80 series ControlLogix...
1,606
Over the next several years, we will be converting 10-20 PLC5 & SLC processors over to Logix format. We already have a handful of 5570 (L7)...
3,800
I've been given VPN access to a customers network. On this network there are several L71 Processors and SE HMI computers. I can see the SE files...
18
6,725
