HELP needed with HMI Proface AGP3200 to Micrologix 1200
brunolife1987
May 2015
indio ca
i need HELP, Hello everyone i have a problem like this, i made just two buttons letter A and B in my Hmi proface AGP 3200 , and i make a simple code in rs logix 500 with 2 N.O contacts and the outputs what am i triying to do is just when i press the buttons in the hmi turn on the outputs in my Micrologix 1200 but i could'nt get that when i press the buttons turn on the corresponding outputs
at the moment ,there is comunication because when i press the buttons the com light goes on i will apreciate very much your help in this issue is urgent Thank you !
(y)
Hello Glshort, Thank you very much but i have already configure the rs logix as the document, i get the com led light turning on when i press the buttons but not the PLC outputs O:0/0 and O:0/1 for buttton A and B , i will appreciate your help thank you!
(y)
I have a siemens 317-2 and an old GOT1000 (GT1675M - V) I am trying to get the darn things communication and having no luck. I have followed the...
2,158
Hi Guys, I have a Siemens HMI that hangs. It is ESA XB300BF4R070 running on Operating System XWIN7P01EN1 customized windows7 Pro 32-bits...
1,353
Hello all, I am relatively new to this site, I see it is very informative. I have been asked to do a project with Delta PLC having 4 digital i/o...
2,717
HI All. Hope you all had a good Easter. Was going to order some some new ABB IRC5 robots, which normally come with DeviceNet option and some IO...
14,771
I have a Baldor MintDriveII controller w/motor and a KPD-TS10C-20 Touchscreen HMI with a "Panel Controller Interface" setup screen where I can...
1,674
