1756-L71 problem communicate with Panel View Plus 600
ajatnika
Mar 2012
Bekasi
Dear All
We use the 1756-L71 uses rslogix 5000 version 20 and Panel View Plus 600 using FTVS Version 6.10. When we change the file.APA to.MER we get error messages like the following:
*** Start RSLinx Enterprise Conversion Messages ***
WARNING: Unsupported device detected. Shortcut name = "Rawa". Device name = "Rawa". Description: The system has detected that a device type that was not supported in the requested version is referenced by a shortcut. If the system upon which this project is to be run has received a patch that adds support for this device type, then this situation will not cause any problems. Otherwise runtime errors will be detected and logged by the target system when it attempts to communicate to that device.
*** End RSLinx Enterprise Conversion Messages ***
Validation completed with warnings. The runtime application has been created.
CAUTION: Running this application might produce errors at runtime.;)
And when we download file.MER to Panel View Plus 600 both cannot communicate error appears on each Tag. Communication is via ethernet EN2T 1756-1783-US08T.
Beg the prompts
Best Regards,
Ajat Jatnika
Hi guys, So I added a routine in a L71, and as is my nature, I selected all of the rungs and pasted them into Notepad++ and then re-imported them...
3,733
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
200
Hi All, We have a number of old discontinued 1756-L1 PLC systems that we are trying to support but recognize that we need to start preparing to...
994
Two days ago I used Control Flash Plus to upgrade the firmware on a 1756-L71 controller from v20.13 to V35.12. The upgrade aborted soon after it...
1,150
I have followed several videos and tutorials that suggest when using the MSG function to enter 2,xxx.xxx.xxx in the Path box in order to connect...
1,413
