I am replacing a powerflex 525 on ethernet/ip with a stratix switch. I am upping the drive from a 2 to 3HP. All i should have to change is drive in the I/O tree if i am correct right? Then plug in the ethernet cabel to the drive. When go online with it do i have to press "create database again or just upload the drive parameters? Thanks guys. Hope i'm on the right path here.
