Redlion Remote Displays
Dylan.Concord
Jan 2018
Mead CO
Hey guys. I have used g15 screens with sn-6001 at&t cellular routers to remote access my screens. my question is can you remote access two screens on the same cellular router at the same time or do in need a cellular router per screen? If i can do multiple screens through 1 router then how would i do that.
I have ZERO experience with remote access outside of a local network, other than a VPN that an IT department setup for me on my pc.
My best guess would be an Ethernet switch and port forwarding ?
When you remote access a Red Lion HMI, if you are remote viewing the display pages, you are controlling the actual screen. Multiple people may access it at the same time, but if you, for example, change pages, the page changes on all views of the screen including the actual hardware.
I don't know what the limit is for how many instances of the web server are allowed at once. I think the only real limit will be your network bandwidth which is pretty minimal for this sort of use and even lower if you are using Crimson 3.1 software and the enhanced web server.
I have not used any of the cell-modem based graphite modules so what I said above may not apply. My experience has been via ethernet networks some of which are wifi based vpn routers.
EDIT: I just reread your post. Do you mean two different HMIs? Or two different views of the same one?
That ought to work fine. They will each have their own IP addresses, and they really don't take much bandwidth, especially with the enhanced (Crimson 3.1) web server.
It will depend on the data rate available to the connection which is impacted by the quality of the cell signal.
Are you using Crimson 3.0 or 3.1?
Hello guys, My question is, is it possible to access my HMI's interface from a PC from anywhere in the world? What I know it works, is the Web...
3,429
Hi, I have a Redlion G306 and its GSM Modem add on which I have successfully managed to send and receive texts from. I'm interested to know...
2,169
Hi Guys, I am trying to download using Crimson 3.0 over the internet using PTV built in Webserver. Can we use webserver to download crimson...
2,877
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
169
