Remote Modification Redlion PTV
whussain6
Oct 2013
Newcastle
108
Hi Guys,
I am trying to download using Crimson 3.0 over the internet using PTV built in Webserver.
Can we use webserver to download crimson program remotely?
I tried it but didnt work
I changed link option to TCP/IP
and then in Communication-Network/Download I have enabled IP Download and selected Port 789. Selection mode Manual and Remote Address is 192.168.1.40.
This IP address I got from the IT guy which is fixed for PTV and the PTV is connected to there network. (It is wireless router)
Also I have ethernet Inputs(Phoneix) connected. Is there any way to find the communication status of these devices from Redlion PTV station? Thanks in advance
Yes you can download remotely but it doesn't use the webserver.
Can you ping the unit at the IP address you were given?
Jeremy
Thanks Jeremy, I have got it working over the wireless router and hope it will work on other LAN as well. As the final network will be LAN.
Just another quick question, I have 8 Phoneix Digital input module connected to PTV through westermo Ethernet switch. If any one is offline/not connected then my program code (on tick) for all 8 will stop working as it is referencing tags which get data from those input modules. Is there any way to get around it?
In the program options there is a check box for Run Anyway. This option allows the code to run if some data is missing.
Jeremy
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
230
See the screenshot of EIP tag list. We are trying to read in a digital input that is hard-wired. It is shown here as I31.1. I believe we cannot...
284
Hello Dear users, I am writing about a problem that has been bothering me for a few days, i.e. I am trying to establish remote access to the Allen...
90
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
221
I have to provide remote access and control to a touch screen. I was thinking about using Weintek and the Weincloud. Does anyone know if this is...
608
