Remote Modification Redlion PTV
whussain6
Oct 2013
Newcastle
108
Hi Guys,
I am trying to download using Crimson 3.0 over the internet using PTV built in Webserver.
Can we use webserver to download crimson program remotely?
I tried it but didnt work
I changed link option to TCP/IP
and then in Communication-Network/Download I have enabled IP Download and selected Port 789. Selection mode Manual and Remote Address is 192.168.1.40.
This IP address I got from the IT guy which is fixed for PTV and the PTV is connected to there network. (It is wireless router)
Also I have ethernet Inputs(Phoneix) connected. Is there any way to find the communication status of these devices from Redlion PTV station? Thanks in advance
Yes you can download remotely but it doesn't use the webserver.
Can you ping the unit at the IP address you were given?
Jeremy
Thanks Jeremy, I have got it working over the wireless router and hope it will work on other LAN as well. As the final network will be LAN.
Just another quick question, I have 8 Phoneix Digital input module connected to PTV through westermo Ethernet switch. If any one is offline/not connected then my program code (on tick) for all 8 will stop working as it is referencing tags which get data from those input modules. Is there any way to get around it?
In the program options there is a check box for Run Anyway. This option allows the code to run if some data is missing.
Jeremy
I am working with a remote rack with a 1771-ASB adapter, and inside Logix 5000 I am trying to find where it displays the status of each of the...
116
Hi all, recently, I deployed Intouch SCADA to the 7 clients PC, but one PC got pending to update the objects and unable to successful. There is...
46
Something I've never thought about before... maybe you folks have some thoughts or experience. I have a customer that uses a Weidmuller, Modbus...
194
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
84
Hello, Can anyone recommend an expandible IO module with OPC UA? I've deployed the Emerson RSTIO-OM module and it works great, but it has a...
66
