Communication between PG and S7 CPU3xx MPI frozen
RMA
Sep 2004
North of Hamburg, Germany
2,052
For the benefit of anyone else who manages to get a Siemens 300 series CPU so confused that it is impossible to communicate with it via the MPI regardless of what you do, you may find some answers to your problem here.
In my case the problems were with a CP5611 and an MPI adapter, but most of it should apply to other devices as well. In particular there is the solution for how to get the MPI back communicating with a normal MPI adapter at 187,5 kb/s. It also involved recovering from ill-considered first attempts at configuring a PC-Station using the Station Configurator in simatic net.
Don't be put off by the thread's title - my first post was in all innocence, but we then proceeded to drag the thread off at a complete tangent! The relevant postings start at Post 11.
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
20
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
75
99
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
114
Or there is an alternative to this? I suppose there are many but I've only seen put/get Can you for example set up a new plc and connect it to an...
305
