Pcs Pro Win
Steve Crotty
Apr 2002
Kingston
202
Anybody know a north american distributor for PCS PRO WIN software? Or a place where you can purchase it and download it on the web?
The only reason I need it is to see what is programming in the unit (PCS 090) so that I can replace it with a PanelView.
Thanks,
Google "PCSPro Lauer" and that should get you there...
Steve,
I have a system with a PCS as well, and downloaded a demo copy of the software from Lauer's website.
http://www.lauer-systeme.net/forum/pcs_f.htm
I also just wanted to see what the code looked like (I had a copy of the source from the vendor)...I've never actually connected to the terminal so I'm not sure if the demo system allows that or not, but it did let me view the source file.
Regards,
Greg
Thanks man, I manged to google that one before, except when you goto download, it asks for a user name / password, which I dont have.
You wouldnt by any chance have it?
I sent an email to them a few days ago but still no reply.
Go to the DemoSoftware section
Steve,
I looked at the website again, and the software I got was the Demo version, which you can get without a password. In the Download area, under the software menu in the upper left there is a Demosoftware link. That's where I got my copy, and as I said, it let me at least view the code.
Regards,
Greg
Not sure about demo capabilities
Turman,
I've never tried to connect to the terminal with the demo version. I suspect you cannot do it, because if the demo has that much capability, why would anyone ever buy the full version? But best is to contact Lauer to see what they say.
Greg
Hi, What is the easiest way to create a Watchdog between 2pcs S7-1200 over Ethernet?
1,516
I am experimenting with a very simple program for testing purposes and not getting any movement from the servo motor. The attached program...
1,792
I dont have connection with this panel. Please help me. Can anybody worked for whis panel? I try connect the rs232-usb cable on the foto, but...
1,149
410E with TP900 different IP range I have a PCS 7 410E REDUNDANCY CPU connected to the TP900 panel, from CPU side the X8 port address is...
951
Hi, I have a question about Siemens ET200M series modules. These will be used in a remote IO panel. In this panel will be a dual redundant Siemens...
1,331
