Communication between Simotion and Linux
wim_
Feb 2010
Belgium
For a scientific instrumentation project, we will be using a Simotion controller, S120, ET200S stations and maybe an S7-300. The idea is that all "lower level" control is performed by the Simotion (+PLC) and that all "higher level" logic is performed by a Linux distributed control system (with most software written in Python and C/C++). This would give us the best of the two worlds: we can benefit from reliable industrial hardware control, and we can reuse nearly all of our custom Linux software.
The one thing that we have our doubts about (probably because we have little experience with it), is the communication between the Linux DCS and the Simotion controller. We would like to send and receive about 20 integers (32 bit) at a rate of 10 Hz, and a larger amount of data (say 200 values of 32 bits) at a rate of at least 2 Hz.
For the Simotion, I think we have two options:
- OPC XML-DA
- custom TCP or UDP communication
Some questions:
- do you see any difficulties we may encounter (i.e. concerning the amount of data transferred at the defined rates)?
- for the TCP or UDP communication, how would that look like in reality? From what I have read on this forum, I'm assuming that we need to write our own protocol? Is it possible to turn the Simotion into a "server", which will return data (TCP or UDP) if we send a predefined command to it?
- Which of the two options would you prefer? A nice open source OPC XML-DA package for Python is available online, so I'm guessing that this would be the "cleanest" solution. However I'm guessing that OPC XML-DA is a lot slower than simple TCP or UDP communication, and maybe we need the speed?
Thank you very much for any advice,
Wim
Connect the Simotion controller to the plc using Profibus/Profinet. Use the plc to transfer data to/from the Simotion controller via DBs. Use your higher level control to send/receive data to the plc DBs.
Hi, guys, how are you? We want to build the communication between SIMOTION D435-2 and main controller AB 1756-L72S Could you tell us which...
1,764
Hi, I would like to ask, does anyone of us have experience in communicating by ethernet between Simotion D435 and Wonderware InTouch? Is it even...
1,368
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
247
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
66
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
140
