Eaton HMI to AB Micrologix 1400 communications
whatever
Sep 2010
Washington State
Hello All,
Have any of you connected an Eaton HMI to an AB Micro on channel 2?
I have AB’s cable to connect to channel 0 and all works fine, however I have a project where we are using a lot of these and I would like to save some money on cables by making my own. The problem with that though is the AB Micro channel 0 is an 8 pin mini din that is not standard. All the connectors I’ve found (digi-key, jameco) have the keyway on the opposite side of the connector than the AB micro. Also the outer jacket is a bit too thick to fit into the housing on the AB. I have been able to modify these connectors but it is time consuming and results in a less secure connection than I’m comfortable with. Consequently I’d like to try to use channel 2 on the AB since it is a normal 9 pin Din connection.
I’ve talked to the Eaton Tech Reps and they told me they haven’t done this.
My Eaton is a Eaton HMI06GE, and my AB is Micrologix 1400 1766-L32AWA.
Any info is appreciated, even negatives.
Hi Whatever!
Had a similar problem with a Panasonic FP-Sigma!
I basically used a ps2 connector and chopped off the plastic locater and removed the pins not needed! Crude but worked! Sorry, can't offer much further help.
Cheers...
Why can you not use the other port on the ML1400? I am pretty sure you can configure it the same as Port 0.
I have been asked to figure out why 2 HMI's will not work at the same time that are connected to a GE 90-30 rack with a 352 CPU. The HMI's are...
2,559
Looking for some help on the red lion side I was able to diver out all the port settings to get the hmi to talk to elc having the are-485 light to...
1,103
Does anyone know if Proface HMI's have the ability to be used on Eaton PLC's? If so, what "manufacturer" device would be used? We have a system...
2,850
Has anyone got a AB to talk to Eaton HMI over ABCIP and have communication be stable?
1,621
Hi to everyone :) Do any of you could so kind to help me deciding what kind of cheap HMI I could use for the PLC model EASY822-DC-TC(EATON)? It...
2,212
