AB Stratix 2000 Ethernet Switch_Power Indication Red instead of Green
AB2005
Nov 2006
Lahore
320
Hi;
I have 02nos AB Stratix 2000 (1783-US05T) Ethernet switches having 5 ports. I have a problem that the Power indications of both switches, which are normally green, are red and switches dont work. i tried to search LED status indicator in manuals but could not.
Does anyone help me out?
Check the polarity on your supply. Stratix 2000 switches will work if 1 of the 2 supplies is wired.
Hello We are having communication problems when we lose power. As you can see on the picture we have 1794-AENTR connected to STRATIX 2000 which...
2,094
Greetings, I had an issue with a RIO rack 2 and IFM I/O Link dropping on my network. I would loose connection for a second or 2 then they would...
93
Kindly, if we enable the routing on the Rockwell Stratix 5700 switch, as in the below link, will it cause any trouble? Like for axis motion...
190
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
96
Hi Guys, I have a Stratix 5700 managed switch that will connected to another different network thus: Stratix 1 on 10.50.3.xx >connect through...
143
