plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old September 8th, 2016, 07:45 PM   #1
Rob S.
United States
Rob S. is offline
Dog Fanuc TP Programs to be able to view in Notepad
Good Evening ,
It has been awhile since I did anything with Fanuc TP programs.
I know there is a way to view them in Notepad. What do you need to
to convert them to be able to view them in Notepad ?
Thanks so much in advance .
Old September 9th, 2016, 04:58 PM   #2
mobsoft
United States
mobsoft is offline
If they are on Ethernet then use the FTP command in the command prompt. I use a commands.txt file that has the switches I want to use when I run my batch file.
For example
commands.txt has the following in it:
anon
prompt
lcd ROBOT_BACKUP
mget *.*
quit
Then I run a batch file with this line in it:
ftp -s:commands.txt XXX.XXX.XXX.XXX
Replace the "X"s with the IP address of the robot.
Make sure the batch file, commands.txt and a folder called ROBOT_BACKUP are all in the same folder. Then run the batch file.
Since I am not using the "bin" switch, the LS files will show up in ASCII instead of binary. add the "bin" switch if you want a binary backup.
Any other questions just ask.
Old September 9th, 2016, 05:11 PM   #3
kwade
United States
kwade is offline
@mobsoft, thanks for that nugget. I dont remember that from class.
Does ftp need any enable for this?
Is there a doc for supported batch commands?
@OP: You should be able to backup the TP programs to a usb stick -- if supported.
Old September 9th, 2016, 05:15 PM   #4
kwade
United States
kwade is offline
Found this:
http://onerobotics.com/2013/10/05/Us...ductivity.html
Got some reading to do...
Old December 3rd, 2019, 07:54 AM   #5
bill4807
United States
bill4807 is offline
When you select backup menu, backup TP programs, select (.LS) file format. You will have to do this individually from the all the above backup i believe
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
AB Versa View keep rebooting?! sutton LIVE PLC Questions And Answers 7 August 21st, 2008 03:10 AM
CLX Ver 16 and DH+ Panel View Donnchadh LIVE PLC Questions And Answers 4 April 16th, 2008 04:44 PM
Notepad in RS View SE kurt.brinker LIVE PLC Questions And Answers 3 August 15th, 2007 04:59 AM
Panel View or RS View? Russ LIVE PLC Questions And Answers 10 August 28th, 2004 10:28 AM
Panel View on DeviceNet paulB LIVE PLC Questions And Answers 0 November 24th, 2003 11:54 AM
