Cimplicity HMI ethernet to Micrologix 1100 problem
jeffdc54
Aug 2006
ohio
I have used Cimplicity HMI 6.1 talking ethernet to a SLC 5/05. However, I cannot seem to get it to talk ethernet to a micrologix 1100. Has anyone done this? If so, what do I have to do differently to talk to the micro than what I did to talk to the SLC? I changed the station number to point to the micrologix but that did not work. I do know that the micrologix 1100 is capable of talking ethernetIP, but I would think it can still talk using standard AB-ETH, I can sure see it in the who window in linx with both AB-ETH and ETHIP.
The MicroLogix 1100 uses only EtherNet/IP encapsulation protocol; it does not support the older proprietary Allen-Bradley "Client/Server Protocol".
There is a lot of overlap between the "Ethernet Devices" and the "EtherNet/IP" driver in RSLinx classic. I doubt such overlap exists in the Cimplicity driver set.
Hi, I am developing project in Cimplicity 9.0 and I want to communicate it with PLC on S90_TRIPLEX protocol. Also want to communicate with...
2,334
I have a question related to the tag definition of a Cimplicity HMI tag. I have an existing application in which I have csv export of the tag DB...
2,047
Hi Members! Can anybody give an useable link where can I download GE-Fanuc CIMPLICITY HMI v6.0 software? I would like to install this software...
2,955
Hello everyone, I'm learning to program the Cimplicity HMI 8.2 recently. Do you have any suggestions where can I find some helpful manuals or...
8,841
Back to forum!📚 I'm working on a project that requires upgrading Cimplicity HMI from Version 7 to 8.2. Does anyone here knows if the new...
4,214
