GE Cimplicity HMI Questions
colorofwind
Jun 2012
Edmonton, Alberta
38
Back to forum!đź“š
I'm working on a project that requires upgrading Cimplicity HMI from Version 7 to 8.2. Does anyone here knows if the new Cimplicity 8.2 is fully compatible with the solution files developed by version 7?
I know this might be a dumb question. Since this is a special environment and the HMI shall not stop, is there any chance the running project be screwed if I click File -> Copy to Project in Workbench to get the solution files?
I've programmed Rockwell PLC and HMI but GE HMI is something new to me. I wonder if someone can suggest some helpful learning resources about this, especially about scripting.
Please feel free to share your opinions. Thanks a lot!
I have never tried "Copy to Project" from Workbench with a running project.
I have often copied a project to another folder from Windows Explorer when it is running.
If you copy the entire folder, it will fail for a lock violation.
What I normally do is to first copy the entire folder and let it fail. I then go into the copied project folder and delete everything except the lock folder. I then select everything in the running project except the lock folder and copy.
With this method, I don't have to create any folders and everything is copied.
I have done this many times and have not yet had a problem.
At the link that RussB posted, search for "CIMPLICITY_Upgrade_Checklist".
This has a list of items to do when upgrading.
If you plan on testing in the same environment, do NOT run two projects with the same name.
Hi, I am developing project in Cimplicity 9.0 and I want to communicate it with PLC on S90_TRIPLEX protocol. Also want to communicate with...
2,337
I have a question related to the tag definition of a Cimplicity HMI tag. I have an existing application in which I have csv export of the tag DB...
2,047
Hi Members! Can anybody give an useable link where can I download GE-Fanuc CIMPLICITY HMI v6.0 software? I would like to install this software...
2,955
Hello everyone, I'm learning to program the Cimplicity HMI 8.2 recently. Do you have any suggestions where can I find some helpful manuals or...
8,843
Hello Everyone, Just finished up some serious coding using the basic programming language within Cimplicity's Script Engine. I wanted to know if...
4,291
