Win CC Alarm Messages
Eng.Abdo
Feb 2010
Saudia
64
i am having 2 project " A-Mill and C-MILL" and both are linked to one server "S7 300".
my objective is to copy the A-MILL (connection, Tags, graphics and alarm messages in C-MILL)
i am done with the first three parts and i have already import the alarm of A-MILL to C-MILL
now what i want is when i monitor and control the screen of A MILL, I want only the alarm messages of A MILL to appear, and when i want to monitor and control the Screen of C MILL i want the Alarm Message of C Mill to appear.... how can i separate both alarm messages while they are in one project?
please help me
thanks
Make each screen alarm have its own address, then just make a
bit that allows only the screen in command to reach the output to that address when the screen you want to view is pulled up.
I take it you have a button to switch between screens, so use that tag to set which screen is in control
thanks Jeramiah, and yes i do have 2 button, one for project a and another for project b, the thing is how i give a specific address to each screen.. please can you help me with more explanation.
thanks
If you select your Alarm Window in WinCC, and open the properties for it, under the heading for "properties" beneath "General" there is a selection for "Filter." If I understand your quandary, what you'll want to do is set up either a tag assignment, or a simple string filter for the difference in the Alarms between Machine A and Machine B.
Of course, this will only work if all the Alarms for each particular machine have a universal string that binds them all together, i.e. - "Machine A Blah blah blah blah Fault One", and "Machine B Blah Blah Blah Blah Fault Forty Two."
thanks man i will try this out.
I just installed a distributed Win911 system replacing a cheap small system I built using Ignition and Twilio. that worked great for the last...
1,028
Is there any way to change the alarm priority after having already defined a digital alarm? Accidentally created some alarms with high priority...
1,497
I having yet more problems with this project especially trying to set up simple alarms and some sort of logging.I set up the alarms as required...
1,884
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
46
Hi All, Got a funny issue. I have a 1756-L85EP and a 1756-EN2TR in the same chase. The client asked for the Ferrari and the 3 lane highway!!! We...
169
