Intouch 7.1 to 9.5 : Invalid Reference or Unknown OCX Method
desty
Feb 2011
Montreal
36
Hi Everyone,
I am currently upgrade a PC which runs Windows NT, Intouch 7.1,SQL Server,OBCD Topics,Rslinx Classic..
The upgrade is to a windows xp machine.
I know intouch 7.1 isnt oficially supported on windows xp, so i did install intouch 9.5.
The conversion doesnt go smoothly at all :( I get a " Invalid Reference or Unknown OCX Method" Pop Up every few windows...
After i tried copying all the *.ocx files i could find in the windows nt intouch folder, but without succes
The few scripts it doesnt convert are pretty huge and i don't have time to analyse every script and try to make an equivalent on intouch 9.5.
So, i was wondering if it's a problem you guys encountered before and know how to fix, or is it better for me to try and install intouch 7.1 on the windows xp machine and try to run it...
i know the maker works fine on windows xp but my issue is, is the 7.1 Viewer working fine on XP...
I have a virtual machine running 7.1 on xp, when i start the viewer i already get an error saying : Intouch OLE Automation error , OLE Object reference is not bound to OLE Object.
Now i am stuck. :(:(
Thank you for your help guys.
The only problems I had with my 7.11 to 9.5 conversion were:
1.Alarm screen needed to be recreated.
2.The application used some external "add-ins" for password entry.
I would recommend that you look at the log viewer in the WonderWare Systems Management Console for clues.
If you can still get into a working 7.1 version of the application on an old machine, take a look at any wizards and activeX components that were loaded. If you are seeing .ocx errors, I wonder if you are missing ActiveX components that need to be installed.
I forget if there is a way to find out what this is if I don't currently have access to the original HMI computer. I only have the InTouch...
6,779
Hello Experts and everyone, I hope everyone is safe in these hard times. As for me, the work still continues on the field. I need help with our...
1,540
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
129
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
108
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
149
