Kepserver opc da driver
ygnm
Feb 2015
vicksburg, ms
85
Any kepserver guru's out there every used the opc da driver with kepserver enterprise? i have it set up where i went through and drilled down to the opc server i want to use and imported all the data that i need from it but when i run the quick client it says it cant communicate with the server. Any help?
What versions of KEPServerEnterprise and KEPServerEX are you running. Changes have been made in both products. I just connected both of the latest versions with no issues
ex is 5.13.191 and enterprise is 5.13.235. i have enterprise reading ex fine but the opc da drive does not exist in the panelview so it cant read the info from enterprise.
it works when i run it as a test on my computer but when i transfer it to the panelview i get item is no longer available. i can navigate through the folders and find the tags i want but no data shows up on the panelview itself.
Some drivers donot exist in the CE version of the Enterprise sever. The DA Client Driver is one of them. Also there is no support in CE for Remote DCOM. You would also have to be able to Configure DCOM Security on the Panel which if I remember correctly you cannot do.
This is by design on the panels.
Is there a way to read an array from S7-300 ? The Kepserver documentation on S7-200 was very clear about the syntax for accessing an array (of...
3,631
Hi all, I was trying to communicate FX3GE PLC with KEPServer / Kepware via UDP protocol but did not succeed. Does anybody has any solution or...
1,097
Hello PLCtalk community, I force to 1 bits in System Platform that are read by KepServer, and for some reason other bits are going down to zero...
3,503
I have nuisance alarm that comes and goes. Doesn't seem to stay longer for a few seconds, is there any way I can somehow add a time delay or...
1,525
Hello. I have an existing Wonderware system connected to existing SLC500 PLC /Flow Computers / RTU as shown in the attached Pic. And Existing...
1,700
