How to to connect RSLOGIX5000 PLC application with Vijeo Citect SCADA Application
mail2jkv
Apr 2009
bangalore, india
Currently i am working with AB PLC RSLOGIX5000 software. I have developed a application in RSLOGIX5000too. Also, using Vijeo citect Software, i have developed a SCADA Application. Both are working independently. But i want to connect the RSLOGIX5000 PLC Application with Vijeo Citect SCADA Application. Can anybody help that how to connect these two application and check together.
Thanks in advance
kathir
Hi Kathir,
It sounds as if a gateway solution could be one way to go. Most likely the two applications use different protocols and thus a gateway may enabled the two to communicate. I work for HMS and we have several gateways.
You will find our Indian distributor at:
http://www.anybus.com/contact/contact2.asp?country=India
or go to http://www.anybus.com/support/support-step.asp?ProdType=Anybus X-gateway
and select what protocols (Fieldbus) the gateway should have and get more info on the product.
If you have any technical questions, let me know.
Patrick L
[email protected]
Hi Patrick,
Currently i working in RSVIEW32 and Vijeo Citect SCADA Software. Here are the list of network/protocols that i am expecting to work.
Ethernet TCP/IP
Devicenet
Modbus Ethernet
ModbusPlus
ProfiNet
Profibus
Modbus Serial Protocol
ASCII Protocol
OPC Protocol
Can you tell me what are the networks/protocols supported by RSVIEW32 and Vijeo citect software among the above?
Hi Kathar,
The Vijeo Citect SCADA most likely uses ModbusTCP. The RSLOGIX5000 on the other hand, I cannot say, but most likely DeviceNet, ControlNet or EtherNet/IP. This depends on what CPU the PLC has.
Maybe some else on this forum, has an Idea.
Best regards
Patrick L
To find the drivers and protocols that Citect can communicate.
Open Citect Explorer go to HELP|Driver Help. These are the pre installed driver/protocols. I believe all the ones you list are there. Of note this to communicate from Citect to the PLC hardware not the software.
As to configure for the control logix platform you would use the ABCLX driver TCPIP protocol. There is a Express Wizard to configure IODevices in the Citect Project Editor. Communication|Express Wizard.
IODevice Setup
Dear Kellian,
Can you please elaborate the steps and procedure in details? I've setup the IODevice using ABCLX protocol but it doesn't seem to be working. (Showing #BAD on the devices using those tags).
Hello Everyone i got a problem with Endress Hauser FlowMeter Promag W400, in his specification says it support Ethernet/IP protocol...
1,781
Hi, Anyone can guide me? Can i run Factory Talk SE client file and communicate with RsLogix5000 emulator by using in a same laptop? If yes, how...
17,891
how to connect Rslogix 5000 emulator and RSview32... I have installed RSlinx also...and i am having virtual backplane...to b fank iam new to...
2,966
139
93
