Connect Factory Talk View and Rslogix5000 emulator in same PC
minaykha
Apr 2009
singapore
96
Anyone can guide me?
Can i run Factory Talk SE client file and communicate with RsLogix5000 emulator by using in a same laptop?
If yes, how can i configure the communication setup.
Thank.
Assuming that you are running a local (as opposed to network) application, and are using RSLinx Enterprise for your server, it's simple. In the communication setup, you should have a 1789-A17 backplane. Right click on it and choose Add Device, then pick ControlLogix 55xx emulator from the list. You'll be prompted for the version, name, and slot number of the emulator. I don't think that the name is critical, but the version and slot number must be correct.
can anyone help with trying to connect a panelview plus 7 to a pc i made a ip address for the panel view i ping it from my pc and its seeing it...
20
3,541
2,440
With Factory I/O you can learn and test your program with a 3D view system Support many automation regular machine,support digital and analog...
5,080
288
102
