Communication problem between LG PLC and Foxboro DCS
suhar
Nov 2008
Jakarta
Dear All,
We currently using LG PLC (Type K120S; Model K7M-DR60U). The unit already has built-in RS-485 communication port. This unit then connected to Foxboro DCS via RS422/485 to FO (use MOXA product)using Modbus protocol. The problem is the Foxboro DCS didn't read data anything which send by our PLC.
I already try using Modbus tester and looks work well
Does anyone please help us to solve this problem
My e-mail address: [email protected]
The Foxboro's people use Fibre Optic(FO) to RS422/485 converter (MOXA TRP-C39). There is the same hardware where used after our PLC.Thx
Hi experts, I have Panelview 800 Teriminal (version 4.012) connected to 5370 compactlogix L2 controller(1769-L24ER-QBFC1B). Through Ethernet...
16,425
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,616
I need some help. I have established communication between the Modicon Premium PLC, using PL7 Pro ver 4.5 software and Adam 6251 remote I/O...
3,825
This Problem happened many times, is it only because the wrong type DB10Q0 should be DB1010 or any other possible cause? HMI log file ...
8,558
Hello, I got 2 S7-200 communicating with each other and a computer with Simatic Softnet Lean 2006 communicating with both PLC. When...
1,443
