Lost communication problem between S7-200 and Softnet
Althalus
Dec 2012
Quebec
Hello,
I got 2 S7-200 communicating with each other and a computer with Simatic Softnet Lean 2006 communicating with both PLC.
When starting my application that communicate with softnet, i got no problem and i got data from each PLC but after a time, between 30-60 minute, i loose connection with the PLC.
If i check the program "S7 connection diagnostic", i got the connection DOWN with error code 10. If i ping the PLC, i got no reply.
If i ping another equipment on my network (wireless modem), after that, im able to have a reply from the PLC and the connection between my application and the PLC is re-establised.
Also, when i lost connection between my plc and softnet, the 2 PLC continue to communicate with each other without error.
My network is has follow, 3 PLC, 1 computer and 2 wireless modem. I did remove the wireless modem but i still got the problem.
Thans for any help you can provide
Some update to my problem.
The problem with the ping was that my router had the same address that my computer but no error message from my computer about having the same IP that some other equipment.
Also, after resolving my IP issue, i let the S7 Connection diagnostic open and when i lost communication, i saw the statut change from DOWN to OK 10-15 time in 1 minute. After a moment, the communication get back OK and im good for 1-2 hours.
problem in a communication that lost bet. S5 135U (ALARM S3964RDDE SERVER) & In Touch Hi all experts and members ...
2,125
Hi all, I was wondering what the protocol is for Ethernet to reestablish interrupted communication and how long this takes. Maybe this info...
1,652
Hi everybody. Does anybody know what is the problem, when CLX has lose communication via ethernet every 5-6 months? CompactLogix have comm...
2,111
Transfered a program and project from one machine to another and no longer have communication. The 2 machines are twin machines in every way. We...
1,384
Hello All, I have an EtherNet 1756-EN2T module connected with L75 processor. From last few days I am facing a problem, the data which I send...
2,133
