Machine cycle time signalising with leds
userxyz
May 2002
any
2,768
We want to visualise to operators the time they have left for each machine cycle. Every cycle parts have to be installed on a product so to indicate the processing timer we are thinking to show a process bar with leds. For example 20 leds to show the time they have left.
Someone know such product that can be bought without the need to install each led individually. We need some kind of bar with leds that we van connect to PLC outputs.
Thanks in advance,
Kind regards,
G
I do have the items you will like, however they are just parts and will need some resistors to make them 24 Volt.
Maybe a seven segment display is good, as you can also give the operator a code when stopped.
Have a look at arduino type of things, as they are cheap and simple.
There is also a lighttower available.
Mind you as you will need some outputs on the PLC.
Another way is a servo motor with a arrow on it. Or cheaper a stepper motor on a arduino.
hi all, i'm sorry, but this is a little long winded. i discovered today that someone years ago created a bunch of formulas incorrectly and it...
6,539
Machine PLC is Allen Bradley using RS5000. I need to use an output for machine end of cycle to trigger a PC, (desktop), that is used for label...
3,235
Hello All, I am stumped on how to convert a %MW to a %MF using Machine Expert Basic and a Modicon M221. The help files show a word to a double...
124
Hello Everybody Anybody knows where I can get this version of SoMachine? The new machine expert version won't open my project saying there is a...
63
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
160
