How can I add color animation to a Tank in Mitsubishi GT Designer3
IdealDan
May 2017
MA
480
Hi Guys,
Urgent help please.
I'm stuck, how can I add color animation to a Tank or any object in Mitsubishi GT Designer3?
I'll appreciate
you can set color/shape/whatever in dependency of word device... just select word lamp
hope it helps
hope it helps
Thanks Sczot for responding.
Where is the word lamp? When I pick up a Tank or import a Tank image, I can't find the word device or lamp you mentioned.
Please help.
Regards.
not sure what do you mean by this...
like screen changes, or navigation inside GT designer?
higly recomends visiting HELP >> MANUAL LIST menu in GT designer and dig through it, once you learn to navigate yourself inside mitsu manual structure your life becomes much easier
Yes, I meant changing/moving from one screen to another
and Lastly setting up security.
Thanks in advance
Thanks in advance
for screen change there is special kind of switch (literally named "Go to screen switch")
for security you will define Security levels under Security menu in System bar on the left side of screen, then setup security level in properties of each screen
You should really dig the manuals
Sczot, Thanks, you have been helpful. I will dig deep into the manual.
One more Thing please, and Sorry to digress, a GOT, Model No. F940GOT-LWD-E having an error msg; "Please install OS" on the screen. What could be the possible solution to it please?
never worked with handy, niether encounter this error, but you should be able to reinstal OS via GT designer somehow
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
140
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
141
Im trying to create a level indicator for water Tank i have used the ADD function while the pump is on and level increasing everything works...
33
1,118
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
622
