Remote screen control
roxusa
Nov 2008
NJ
994
Looking to change screen on a pv+1000 from SLC
I have added tags to the following
Replace Display Number (F197:75)
Remote Display Number (F197:70)
Close an On Top Display (F197:72)
I would like to change to a screen on an event and hold it until the supervisor releases it. I was thinking I send screen number to F197:70 and have a numeric key pad entry button on it so supervisor could enter PIN number that would fire a rung to put the zero back in F197:70. I could then also have a screen selector button on that screen which should be active once the zero is set in F197:70
Do I need the Close on to Display?
Anyone have a better Idea I need to put in a screen that tells crew they won a gift certificate if they break a production goal!
I don't think you should be using an F file address for your PLC controlled screen number... use an N file address.
Thanks, I had addressed it in my program and then inadvertently made it an f file in the Factory talk since I use cut and paste on the tags.. I am not getting any errors now and I can see the screen number I am on in the N register associated with it. Hopefully everything else will work to
What is happening when a panelview 550 says "remote device has screen control press any key" error 436 I have a SLC 500 and pv 500 which...
5,172
I currently have an application using PVC and ML1400. I'm controlling the screen(s) to be displayed with the plc logic via the Global Connection...
8,050
We are having a problem with selecting a screen remotely controlled from a PLC. The panel view displays a message stating it is remotely...
2,321
I have been looking a device that can allow me to remotely monitor HMI EA9 8" automationdirect cmore screen. Problem is hmi is connected to local...
2,764
Hi all, I have a proposed application that I would like to implement but I'm not sure if it is feasible (or possible) to do and wondered if...
2,865
