Connecting two PC adaptors to the same port on a S7-300 PLC
islman1975
Jan 2005
We have two PC adaptors, 1 serial, 1 usb and one S7-300 PLC with one MPI port, (and 1 busted profibus port) We want to connect both PC adaptos i.e two PC one running Step 7 and the other running Kepserver for IO simulation and testing purposes. So we need to make a y connector with one male 9-Way Dtype to fit PLC MPI port and then to two female 9_Way Dtype to connect the two PC adaptors. Can someone let me know which pins we need to connect up to get MPI communications and both PC adaptors powered from the PLC MPI port. I've found the following pinouts. Apart from 3,8 what else do I need. Thanks
+ Pin No.+-Signal Name+-Meaning++++++++++++++++++
+ 1 + – + – +
+ 2 + M24V + Chassis 24 V +
+ 3 + RxD/TxD-P + Data line B 9 4 +
+ 4 + RTS + Request To Send +
+ 5 + M5V2 + Data ref.vol.(of station)+
+ 6 + P5V2 + Pwr plus (from station)2 +
+ 7 + P24V + 24 V 1 +
+ 8 + RxD/TxD-N + Data line A +
+ 9 + – + – +
Ugh - something tells me that bad things will happen if both devices try to communicate. If it's just one at a time for testing purposes, try using a cheap manual switch box. If it's concurrency you're after - Ethernet.
+ 1 + – + – +
+ 9 + – + – +
No it works fine I've done it in the past but i lost the adaptor I made up. We've just done it and it works ok have done all severn pins as we were uncertain which ones we would need and left pins 1 and 9 disconnected.
Ok, I'll take your word on it. Hopefully someone else has done the same and has your answer.
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
32
81
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
90
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
229
Hi, I want to build a demo station to test devices and programs and I need some help with it. I want to connect GuardLogix, Piltzmulti and...
149
