Difference between Proces Control PID and Temperature Control PID.
JesperMP
Feb 2003
ᚴᚬᛒᛅᚾᚼᚬᚠᚾ
16,324
whats the difference between the above two types of PID controllers.
For example, there are the S7 PID blocks FB41 CONT_C and FB58 TCONT_CP.
Is it just that a "temperature" PID is allways pulsed heat or cool or heat/cool, or is there more to it ?
The controlling funktion is the same..
however, with FB41 are more settings possible and
takes more time to process in the CPU.
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,413
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,042
Good Morning , I have 2 Frequency Drive panels to build and commission . It is for 2 pump systems . Just wondering , what is the...
1,971
Hi Experts, Good day! What are the differences between PCS7 SIMATIC Batch and PM Control? Do you have any manual like "Getting Started "...
813
I have a Automation Direct Click Plus that you can buy option CPU slot modules for input/outputs. The slot modules have the options of sinking...
2,831
