Downloading PLC Program to Controller Error
SWARP3
Mar 2023
Minnesota
Hello,
I am attempting to download a program someone else created to an existing PLC (1769-L24ER-QB1B CompactLogix5370 Controller). However, when I initiate the download I am met with an error... "Error: Rung 3, OTE, Operand 0: Invalid bit specifier."
This error points to an individual bit in the program like "MD_X2000:O.Data[2].10" ... And, when I search in controller tags it maxes out at Data[2].7
I'm guessing it has something to do with my base data type size?
Any help is appreciated!
You are correct that it is related to data type -- the tag is an array of SINT (since it has 8 bits per member), so any bit address above 7 is not valid.
As alan_505 refers to, the array is part of a system-generated tag for an IO device or module named MD_X2000, meaning either the programmer incorrectly set it up when creating it the in the IO tree or misremembered how the data was formatted when programming the OTE (or just had a typo).
If you have the manual for the device you may be able to cross-reference it with what the program is doing to figure out which and correct the issue. Or contact the programmer.
Hi, I'm looking for advice about downloading the program from a PLC and storing it in a form that can easily be uploaded back to a PLC. I am able...
2,390
I have a Q00 PLC from a customer who want to modify some in Main program. First I upload program from PLC using GXWork 2. Everything is ok. But...
4,424
I have a Millennium 3 CD12 PLC dating from around 2008. I'd like to download and modify the current program on it. When I connect to it and click...
2,119
[Just realized my 100th post! wohooo] Hey everyone it has been a while, I have a few questions regarding download for the siemens experts more...
2,208
I need to do some research on Mitsubishi PLC program. I want to download original program (made by someone else, I have no source code) and save...
9,041
