Wonderware Archestra Script Problem "could not resolve reference"
douglasfcx
Mar 2014
Gyn
Using: Wonderware System Plataform 3.0 SP2; Intouch 10 SP2.
I used the Archestra to create objects using a script to automatically assign object attribute I/O references based upon the object instance name.
It was working fine but in some point, when I needed to create new objects, the script stopped to work. The same script that worked for the older objects dont create the references anymore.
The objects indicate one Warning for each reference in script, in the objects properties I can check the warning messages:
"Warning - Script: Could not resolve reference Me.Script.ExecutionCnt in attribute - Script._ExternalReferences"
"Warning - Script: Could not resolve reference Me.Tagname in attribute - Script._ExternalReferences"
"Warning - Script: Could not resolve reference Me.At in attribute - Script._ExternalReferences"
This is the script:
Script Name: Script; ExecutionType: Execute;
Expression: Me.Script.ExecutionCnt <= 2 AND Me.Ready==false;
Trigger Type: While True;
if Me.Script.ExecutionCnt == 2 then
Dim sString as System.String;
sString = Me.Tagname;
Me.NameTag = sString.Remove(0,sString.IndexOf("_")+ 1);
Me.At.InputSource = "PLC." + Me.NameTag + ".At";
Me.St.InputSource = "PLC." + Me.NameTag + ".St";
Me.Alr.InputSource = "PLC." + Me.NameTag + ".Alr";
Me.Mnt.InputSource = "PLC." + Me.NameTag + ".Mnt";
Me.Sd.InputSource = "PLC." + Me.NameTag + ".Sd";
Me.Clr.InputSource = "PLC." + Me.NameTag + ".Clr";
Me.Fal.InputSource = "PLC." + Me.NameTag + ".Fal";
Me.Te.InputSource = "PLC." + Me.NameTag + ".Te";
Me.Fr.InputSource = "PLC." + Me.NameTag + ".Fr";
Me.Fw.InputSource = "PLC." + Me.NameTag + ".Fw";
Me.En.InputSource = "PLC." + Me.NameTag + ".En";
Me.Ready = true;
endif;
I use Tagname field to remove the "underline" and then i use the name of object in NameTag, to use the same name that the PLC (ControlLogix5000).
What could I do for that the Archestra execute the script for the new objects?
Hey I was needing help with some alarm scripting in Woderware System Platform. What would be the best way to write a script to auto acknowledge...
2,550
Hi, I am trying to use Script function Library. I used Visual Studio to write the C# dll i will import in Archestra. So I import my dll...
2,587
I am trying to use lots same scripts in the ArchestrA IDE, so I decide to develop Custom Script Functions in Visual Studio for AppServer. I know...
6,985
Anyone have any new stories with a .net script? I'm trying to grasp my capabilities as far as what I can call out from the windows system. Am I...
1,301
Hi ! im having some trouble with the following code.. ------------------------------------------------------------------------ dim sr as...
2,932
