plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 2nd, 2016, 04:33 PM   #1
noorloai
Canada
noorloai is offline
Omron PLC- CJ1W-DA021 Analog output Programming help required
Hi all,
I only do PLC Programming on and off and have never done programming analog stuff therefor I need a pointer in the right direction.
We have been asked to add digital air regulator to our xpleater machine. I am using sysmac studio with the CJ1WDA021 this module has 2points analog outputs to control the digital regulator measured pressure in psi.
Simply, PLC will calculate the necessary tension pressure. This will be the base multiplied by one of two constants coming from the HMI. This pressure value will be converted to an appropriate analog output value which will be sent to the analog output module.
I have added the module to the cpu rack, and did the configuration from the right side (Edit special unit settings) I used 1-5V (4-20mA) output signal range.
The set value is the number between 0-4000 BUT HOW CAN I FIGURE THIS NUMBER base on what? see the attached picture!
Another question, how can I determine what the appropriate analog out values need to be to have the digital regulator deliver the correct pressure?
Thanks again for any support you can provide.
Old January 3rd, 2016, 01:16 AM   #2
BobB
Australia
BobB is offline
BobB's Avatar
I cannot help you with Studio as I refuse to use it - I use CX-One. I detest tag based programming - too slow - too fiddly. As far as the card goes 0-4000 = either 1-5V or 4-20ma. You may have to turn bits on for the analogues to work - in CX-One if the address allocated is 2000 then bits 2000.00 and 1000.01 have to be turned on to enable the outputs.
__________________
The Old Pfhaart
Old March 15th, 2017, 01:59 PM   #3
alecueto55
Cuba
alecueto55 is offline
Quote:
Please I need a little help with a CQM1 plc and a DA021 because I need to control a sysdrive 3G3EV with the DA021, i dont know exactly how configure too 4-20ma and to what address send the data to be converted to Analog output, i see something about APR function but I dont see any practical example
Old March 16th, 2017, 12:06 PM   #4
gtsuport
United States
gtsuport is offline
The information you need is in the W238 manual.
Please see the link below for the manual.
https://downloads.omron.eu/IAB/Produ...W238-E1-10.pdf
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Analog output (ABB AC500 PLC ) scaling muza1988 LIVE PLC Questions And Answers 3 March 8th, 2015 12:05 PM
A PLC simulator with analog input \ output emulation KaktusJack LIVE PLC Questions And Answers 2 February 5th, 2008 03:21 PM
Omron Sysmac C200H PLC + High Density Output Unit + Syswin 3.4 = Non-Recognition! Tribochet LIVE PLC Questions And Answers 4 July 16th, 2007 05:35 AM
PLC analog input output rate tom2378 LIVE PLC Questions And Answers 3 March 15th, 2004 06:09 AM
omron CPM2A plc pulse output direoasis LIVE PLC Questions And Answers 2 September 20th, 2002 04:26 PM
