S7 300 TCP\IP data send on TIA Portal V13
Szabycsek
Nov 2016
Jászjákóhalma
Dear Experts,
I have a CPU 315-2 DP (6ES7 315-2AG10-0AB0) and CP 343-1 (6GK7 343-1EX30-0XE0) in TIA Portal V13.
The ethernet card connected to a factory network (IP adress: 192.168.2.1).
I have a PC also in this factory network (IP adress: 192.168.2.3, Port: 9200).
I need to send data over TCP\IP from PLC to PC.
How I can do this? The T_SEND and T_RCV not working...
Please help me. Thank you everybody.
T_Send does not work with a CP card it only works with the internal interface.
You have to set up a connection and use AG_Send, AG_Receive functions
We have a Powerflex 753 drive on a 192.168.1.X network that I can communicate with a Controllogix L71 with no issues on same network...
1,461
Dear All I have worked with MODBUS TCP and RTU many times and commissioned successfully. Here First time I m working with S7300 to establish...
3,211
My dearest colleagues, Could I connect Siemens PLC S7-300 with CP 343-1 lean communication module over PROFINET/MODBUS converter such as...
8,096
Dear All, Currently we are trying for a configuration with below details R system Siemens PLC S7-300 315-2dp 2 no of cp343-1 lean for...
3,897
I'm currently having issues with delays in sending and receiving information between the Tricon and C300. Here is how my network is setup: 1.The...
3,889
