victorbrave
We have a Powerflex 753 drive on a 192.168.1.X network that I can communicate with a Controllogix L71 with no issues on same network (192.168.1.x), PLC is just there for testing, I can read logic status words and run/stop from PLC. Plus I can see/write all the datalinks I created. Then I disconnect the PLC from the network to avoid ownership to the drive, cycled power to drive.
We have a Experion C300 with the AOP for Powerflex drives and it doesn't want to connect to the drive, C300 is on 10.30.40.x network downlinking through stratix switches to the 192.168.1.x network level.
Once I tested the AB PLC to Powerflex communications correctly, is there anything I would need to change/add to my Powerflex configuration to talk to the C300 in this type of setup?
Any ideas? please help, TIA!
