rakeshkhawas10
I have a requirement to get SOE data from Triconex's Trident controller to Honeywell's Experion system. Trident has CIM module (Model 3211), with inbuilt OPC Server.
In one of my previous jobs, I had used Maticon's OPC Server for Trident to get the SOE data into Honeywell's Experion system. That was because the Communication Module then did not have inbuilt OPC Server feature. So the SOE file had to be manually copied into the OPC Server for it to know the tags list. Now that the OPC server is configured in the CIM module, I am not sure if anything needs to be done with the SOE file, or does the CIM gets the SOE tags directly from the Trident.
Does anyone know if the SOE file is still required. If so, how do I use it?
