OMRON CJ1M-CPU13 integration issue with NS12-TS01B
shyam_m
Mar 2017
Dubai
Hi All,
In the year of 2008, My site has been commissioned with Omron PLC CJ1M-CPU13 and HMI touch screen interface NS12-TS01B-V2 for gate control application.
Recently I tried to replace the old PLC with recently purchased CJ1M-CPU13. After replacing the PLC, The HMI Touch screen panel is not communicating with PLC. I am getting error below error .
Communication error detected while writing by the following case.
- Corrupted data by Noise.
-Transmit error by the host.
Allocation Host: HOST3
MRES=05, SRES=01
as per NS error document,"No destination Address set on routing table ( SPES:01)" is the route cause for the error. I have manually added Routing table to the TSP but still I am facing same issue. If I replace old series PLC, it works fine without any issues.
I am struck with this issue as the replacement PLC is not working. This PLC is used for one of the critical gate operation. Please advise me to resolve the issue.
Proceeding with my analysis, I have Noticed below version/revision changes with PLC's.
OLD PLC: Revision D, PCB revision - AB-, Software revision - AB 1.
NEW PLC: Revision L, PCB revision - EB_, Software revision - BE 4.
Is there any compatibility issues with NEW PLC & TSP ?.
Is there any downgrade of software revision will help me to resolve the issue ?.
Hello Guys, I have a machine that have 8 Omron 3G3MV VFDs and I am looking to migrate to Omron 3G3MX2 drives. the existing network is half duplex...
573
Hello! I have i little problem with comunication between the PLC and Yaskawa A1000 invertet. I set up all the parameter in the inverter and i add...
2,680
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
252
hi dear all hope you all are fine I have a problem with my CJ1M cpu11 ETN. it stop communication with PC over ethernet. ETN unit all indications...
169
Hello everyone. I am new when it comes to Omron PLCs. Currently I'm uploading program from CJ1M PLC using CS1W-CIF31 cable only. I connected the...
161
