OMRON CJ1M CPU11 Program Upload
AndrewThu129
Dec 2023
Yangon
Hello everyone. I am new when it comes to Omron PLCs.
Currently I'm uploading program from CJ1M PLC using CS1W-CIF31 cable only. I connected the serial (RS232) port of the PLC to my PC and tried to go auto online with CX-Programmer.
But everytime I try to search the PLC, it returns with an error saying "Failed to connect to the PLC".
My question is that is it possible to upload program with only one cable [CS1W-CIF31]?
The CS1W-CIF31 cable is more or less a standard USB to RS232C converter. You'll need an additional connection to the Host Link port (DE9). You can make the cable yourself. See below. You can perform the Auto Online function but if you don't have success, you can set DIP SW #5 to ON then the serial parameters will be 9600, 7, Even, 2.
The image shows "Option Board" but all Omron Host Link ports are nearly the same.
Hi dear . I have a system with cj1m cpu11 etn. previously NT 5z HMI was connected with plc. recently my old HMI got damaged. I want to replace it...
252
hi dear all hope you all are fine I have a problem with my CJ1M cpu11 ETN. it stop communication with PC over ethernet. ETN unit all indications...
170
Hello, I have PLC Omron CJ1M/CPU11, the problem is whenever i connect the PLC to my PC (laptop) via serial port and try to go direct...
2,457
Hey, new to Omron. I have a CJ1M CPU11 PLC that I need to connect to and backup. When I look up Omron programming software, I find three different...
1,679
Hi everybody, I can't transfer data from laptop to omron sysmac cj1m cpu11. I use cable "omron cs1w-cn118" and Uport 1150 (RS232),I sure software...
3,915
