1" water valve slow opening and closing
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,791
This is for a tank fill application that has a PVC ball valve at present. The operators often open the valve and forget about it, overfilling a tank. We are tasked automating this.
I have it all worked out except for choosing a valve.
The problem is that the 100psi water line is 1" PVC, and subject to severe water hammer during both opening and closing.
I have used the slow closing ASCO red hat valves before, but I think they open quickly. We want it simple and reliable but need to open and close slowly. About ten seconds in each direction would be slow enough if not adjustable.
If I use a motorized ball valve, that is overkill for this on/off operation and then there's the concern about what happens if power is lost.
I have searched quite a bit and found a few potential candidates, but they're all either cheap looking, only speed controlled in one direction, or ridiculously overkill motorized valves with analog control.
I know some of you guys probably can direct me to the exact product I need to locate.
Paul
You could use a solenoid operated "Pump Control Valve" like a Cla-Val. the solenoid operates a small valve that uses line side pressure to force open the main valve slowly. When you want to close it, you cut off the solenoid power, the water drains from behind it and the main valve re-closes, also slowly. They are designed to specifically reduce water hammer. Because it closes by cutting off power to the solenoid, it functions exactly the same when power is lost. http://www.cla-valpacific.com/136-01636-01-solenoid-control-valve-p-60.html
You might be able to use your solenoid operated Red Hat style valve with a spring return to closed (for dealing with a power failure), but after that valve, install a hydraulically dampened check valve, also called a "silent check valve". They also are used specifically for the purpose of reducing water hammer. Apco is the one I'm most familiar with.
http://www.dezurik.com/products/product-line/check-valves/silent-check-valves-csc/8/39/
The thing with that though, I don't know how that would be able to dampen the water hammer on a fast closure of a valve, they usually work in conjunction with a centrifugal pump because the pump slows down, it doesn't immediately stop flow.
I would use a diaphragm valve. I couldn't give you the brand name, I don't remember, but it is a 0-1A air valve that actuates a diaphragm to allow water to flow. We used these on steam hot water heating systems and had a rate setting on the controllers to limit how fast the water could open and close. These are available with or without feedback (and in your case you wouldn't need feedback).
When you get the low low setpoint, the 0-1A to the air valve is stepped up (we used 4-20mA with a transducer to isolate the load.
It hits max open and and stays there until high point is reached, at which point it steps down.
You could easily do this with a PLC for a controller or get a dedicated controller for the purpose.
I should add, the diaphragm valves are expensive, but everything else is pretty cheap. Drier, regulator, 0-1A air valve and around a hundred bucks for a process controller.
Do you have air available? If so, use an air actuated valve. It's super easy to resttict the air for slow open/close.
Thanks for the feedback so far. We don't have air available for this application. It needs to open fully in order to fill the vessel quickly so I don't want to restrict it. The valve fills a mixing chamber to which they add bags of powdered carbon. The operator is not a fan of Cla-val valves due to issues (mainly lack of maintenance) at other locations with big valves.
The principle looks right though, so I may have to check into the cost and sizes. This water line is all 1" PVC that snakes up and over a door with a valve conveniently mounted on the wall near the door handle. Our plan was to install an automated valve just after the hand valve and leave the hand valve open during normal operation, but it could be closed to work on the new valve or in the event of a leak or failure.
I'd like a simple red hat valve that operates slowly both ways which would be simple, reliable, and would close during a power failure. It might be more feasible to go with the slow closing valve and address the fast opening by better securing the piping before and after the thing.
Try these from Burkert. https://www.burkert.co.nz/en/type/6211
Not cheap either unfortunately but I use them on our carry water lines and they cause less hammer that ones which are direct acting. These are servo-assisted so the water pressure behind the valve opens it.
Securing the pipework will be a good idea too.
The other option is a small PRV upstream to help dampen the surge by providing less pressure downstream for the valve to close against.
Paul
I have a very similar project coming up in July. Please post the valve you end up choosing and how it worked out.
Hello everyone I need some suggestion from you. We are controlling the flow of water in one of application. Our problem is the set point is...
3,988
Hey Guys, I've got an application where I need to shut off water supply when an estop is pressed, and I'm having a hard time finding a safety...
3,721
Completely new to PLC's but need advice on what to buy and program to activate a 1", 24v water valve for 4-6 seconds every 10 minutes. I thought...
22
6,964
I'm trying to do proportional control of a valve on a water tank without the use of a PLC. Does any one has any experience using a PID control...
2,703
I should know this , but we had a modulating water valve go bad this morning. I would like for the guys to test this on the bench. How can I take...
10,064
