Safety Shutoff Valve for Water
benaiahhenry
Sep 2011
Corning, NY
265
Hey Guys,
I've got an application where I need to shut off water supply when an estop is pressed, and I'm having a hard time finding a safety rated valve to do that with.
SMC makes stuff like this for air. I need something like this for water.
I don't have to worry about venting out the water like I would with air though because the other end of the line is an open drain.
The system needs to meet a PLd.
Have any of you guys dealt with dumping water on an estop?
Thanks!
-Benaiah
you may also want to consider 2 valves in series to provide additional protection / redundancy of the valve if it is a critical application
Yes, I am planning on doing that as well. The main part I've been having problems with is the feedback from the valve.
-Benaiah
What is the application? are you using a Pump or is it mains feed?
if it is as you say open to drain and venting is not an issue, so there is no possibility of the system holding pressure after an E-Stop
You could shut down the pump via STO on the VSD or Dual Contactors thats of course if you are using a pump
After some interesting conversation regarding the safety of emergency stops, I saw some posts talking about the safety standard conversation...
24
648
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
110
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
105
Hi I have a yaskawa gp7 robot arm which I am going to use for machine tending with a cnc mill. Is it a good idea to buy a SICK laser scanner for...
240
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
116
