Question about SICK Safety Laser-scanner for robot arm
Lennytheman
Apr 2024
Gothenburg
Hi
I have a yaskawa gp7 robot arm which I am going to use for machine tending with a cnc mill.
Is it a good idea to buy a SICK laser scanner for safety purposes inside the cell?
I see them go for pretty cheap on ebay
The idea is to make the robot arm stop if i go inside the cell
And then continue when i exit
Yes, that's a common use for a safety scanner. Connect it the robot's fence input or if the robot has a safe input for "Pause". May have to do a little bit of trickery to restart on it own.
Just be aware of a problem I had to find on a system with the sick barrier, was called to a system where for no apparent reason the light barrier kept tripping on it's own, I checked everything like noise loose wires you name it, bearing in mind this had been running for about 18 months without problems, I noticed that the system tripped sometimes when a forklift passed, turns out that originally there was another bit of plant next to the system, this was removed to allow for forklift trucks to pass, it was the amber beacon on the forkloift causing the trip, a quick fix was to place a screen (in my case a flattened cardboard box tied to the cell cage so the beacon would not interfere with the barrier), I informed them that my heath robinson fix should be replaced with something more appropriate, two years later it was still there.
Be careful using auto restart. The SICK Flexisoft safety controller has some good tools built in to set up zone profiles. In my view it would be better to have a pushbutton outside of the cell which you can press to reset the unit when you exit.
Thank you all for this very good info
I have now bought the sick controller and will install it along with my robot
Very weird with the forklift setting it off, good info to keep in mind
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
176
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
76
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
97
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
100
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
83
