plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old April 26th, 2017, 02:30 AM   #1
martinshaw
United Kingdom
martinshaw is offline
Rockwell Historian SE 4.00.01 and MS SQL Server Express
Hi
Really quick question.
Rockwell Historian SE 4.00.01 has MS SQL Server Express behind it. In a previous life, using Wonderware InSQL Historian, I remember being able to access the SQL database behind the application directly (AnalogHistory, DiscreteHistory, etc tables) using different database administration tools, Toad being one of them. Its this possible with Rockwell's Historian and does anybody know what the database configuration is in terms of tables and relationships?
I should point out that the Rockwell Historian is due to arrive on site in a couple of months so I want to get a bit of background information before hand.
Martin
Old April 26th, 2017, 06:50 AM   #2
Dravik
United States
Dravik is offline
The actual data is not stored in SQL w/ FactoryTalk Historian. It is stored in flat files.
If you want to access the historical data using OLEDB/ODBC style connectivity you'll be wanting to purchase and install the Advanced Server option.
The SQL stores the Asset Framework configuration and other things however, I can probably dump the schema of mine if you are curious.
Old April 26th, 2017, 07:00 AM   #3
martinshaw
United Kingdom
Hi Dravik
Thanks for the reply.
From memory, Wonderware InSQL was also in flat files but if you used a standard query tool (for example Toad for SQL Server), you could get to the data. but only historic, not live. I must say though, its over 10 years since I played with that technology so I could have been mistaken.
I would be interested in your offer of a schema though. I am definitely curious.
Just as thought, if you login to the SQL Server database behind your Rockwell historian, what tables do you see?
Martin.
Old April 26th, 2017, 07:18 AM   #4
dmargineau
United States
dmargineau is offline
dmargineau's Avatar
Any of the MS SQLs databases associated with FactoryTalk products (including FTHSE) are locked-up and available exclusively to the Rockwell application install which they are related to; one cannot 'look-up' the SQL files since there are no available 'SQL Manager" type tools.
In fact, the SQL installed by FTHSE does not contain any 'historical' data since any implemented FTHSE databases are PI (Time-Series) containers as opposed to SQL-relational type ones.
FTVantage-Point and/or FTView SE (the Historian 'front-end") use the FTHSE SQL for Historian SE database connectivity.
Old February 8th, 2018, 04:48 AM   #5
martinshaw
United Kingdom
I know this thread has been dormant for a while but I have a few more questions and observations.
We got FT Historian SE installed in August last year (2017) and its been happily sat there collection data from various PLC's and SCADA's around site. Yesterday was the first time we have tried to use it to view the data and it proved a little disappointing.
I was wanting to simply look at historical data for 10 items over a specific time period of three hours on a specific day and create a graph of the results. I used the PI DataLink excel addin to query the historian data and found that although the wizard looked like it would accept multiple items to select, it would only select one. And then I had to create the graph manually.
I then tried the PI System Management tool to export to CSV (and then to excel and create the graph manually), and although it looked like it had selected multiple items, it grouped them all together and there was no way to separate them.
Is it really the case that in order to display the collected data in some meaningful way, I have to create trend on a scada screen through FTView or use FTVantage-Point? Maybe I'm missing something?
Old February 8th, 2018, 08:00 AM   #6
crawler009
Switzerland
crawler009 is offline
crawler009's Avatar
Not totally correct, imho. Or i understood you wrong, then im sorry.
I use the standard Datalog from FTVSE, and log the data into a MS SQL (express). Then i use DreamReport to get the data out of the SQL database for further use, print reports and trends.
here is the screenshot in higher resolution: https://ibb.co/er4qMH
Last edited by crawler009; February 8th, 2018 at 08:03 AM. Reason: added picture link
Old April 17th, 2018, 06:35 AM   #7
martinshaw
United Kingdom
Update on the whole historian / excel question
Yesterday, I spoke to Rockwell and they confirmed that to query the historian as a relational database, I need to purchase the Advanced Server Options as Dravik suggested. As money is tight, I looked at a demo of XLReporter.
It does exactly what I want. I connects directly to the historian using ODBC and I can pick multiple tags across a specified time period and display the data, either tabulated or graphically. It looks like its a fraction of the cost of the Advanced Server Options too so it looks like this might be the way to go for my particular requirements.
Old April 17th, 2018, 06:50 AM   #8
seth350
United States
seth350 is offline
seth350's Avatar
Look at Metabase. It’s free and really really nice.
__________________
“Did the Lord say that machines outta take the place of livin’, and what’s the substitute for bread and beans? Do engines get rewarded for their steam?” -John Henry
Old April 17th, 2018, 07:37 AM   #9
martinshaw
United Kingdom
Does Metabase work on windows OS and connect to Rockwell historian? Looking through the user guide, it looks like it will only connect to a regular database and not a historian?
Old April 17th, 2018, 08:11 AM   #10
seth350
United States
seth350 is offline
seth350's Avatar
Yes it runs on Windows and provides a web server with login information for multiple users.
Idk about historians...
__________________
Old April 17th, 2018, 01:20 PM   #11
janner_10
Supporting Member
United Kingdom
janner_10 is offline
This is what we use, it is by far the easiest and less messy way. The less you introduce factorytalk into things, the better and more robust the data collection is IMO.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Ftv: Ms sql server 2008 r2 Seyed Mohamed LIVE PLC Questions And Answers 5 December 28th, 2015 07:10 AM
Factory Talk View SE to MS SQL database creation fails!! mahone LIVE PLC Questions And Answers 1 May 31st, 2015 01:18 AM
MS SQL Server or Other robw53 LIVE PLC Questions And Answers 10 May 17th, 2012 02:33 PM
OT mrplc offline? BobB LIVE PLC Questions And Answers 28 December 31st, 2008 06:02 AM
Is there an "MS SQL Server Express for dummies" somewhere ? JesperMP LIVE PLC Questions And Answers 6 February 27th, 2008 05:54 AM
