can not turn on the motor with PLC
backendcode
Aug 2017
brampton
249
Hello Guys,
This is my first PLC project of the conveyor system. I am trying to test my code and turning on my motor with start button on the control panel. When I press the start button, I can see motor output bit 1 but my actual motor does not start.
I attached electrical circuit of a motor and my PLC code. Please someone can help me if I am doing something wrong.
https://ibb.co/dch0WG (electrical schematic of motor)
https://ibb.co/h9cpQb (PLC code)
Thank you,
Is the s/w routine that that the rung of code is in actually being executed?
Grab a volt meter. Does the motor contactor energize? No? Is the MOL tripped? Reset it. Do you have a control voltage at the PLC output when it is activated? No, check the power common to the output module. Yes? check for voltage between the MOL and contactor coil.
Diagnostics is just a matter of eliminating things that can go wrong.
When our maintenance guy manually pressed the contactor, it turns on the motor which means motor overload is not tripped ( i guess) and when I turn on the output bit of motor with PLC, I can see my output card show an indicator light but my contactor doesn't energized!
Test the contact on the PLC output card to make sure it's actually energizing. A bad output could fail to close the contact even if the light turns on. If you get your current reading, then check the other end of the wire to make sure you don't have a broken wire. Just keep moving one step down the chain with your meter until you figure out where it stops. That should pinpoint the problem.
I agree but How come when Maintainace guy manually press with contact, it turns on the motor? if wire is broken, it should turn on either way (i guess)
thanks
Personally,
I would break the code up in to these routines.
Input
Motor
Output
I don't like mapping IO around in the actual code. Then you should be able to see if the code is actually trying to turn the output on or if the code isn't working.
Well, what have you done to troubleshoot the electrical part of it? Are you a qualified electrician? I mean, do you know enough not to smoke yourself?
The code seems fine.
thanks
The maintenance guy is performing the function of the coil. So everything in the coil circuit is suspect, all the way back to the s/w.
The output card needs to be the correct type. They make AC/DC volt/current output cards, but that motor contact is looking for one specific type. Probably either 120 AC or 24 DC, but I wouldn't be surprised if there are others out there. Was the card chosen by someone that has experience with this sort of thing?
The PLC output is just sending a signal to close a contact on the motor and allow it to receive the higher voltage power to run. The output isn't supplying the power to run the motor. Manually closing the contact doesn't verify whether or not the signal from the output card is reaching the contact.
Please check this link
https://ibb.co/nr2Okb
Can you please explain me what is this? When I puss this to 1, then my PLC code work and it turn on the motor. how can I pull in with PLC code?
I think my NC estop energizing this device? i guess? Because there is label on this device CR60044 AND in my electrical diagram, e-stop energized this coil
Hi all, I have a powerflex 525 where there is no voltage coming out to the motor. The drive was reset to factory defaults with stop and saftey...
2,767
I got a call yesterday from a plant that I support. They had a powerflex 755 vfd that from what myself and the other controls engineer can tell...
4,270
I know this should be pretty simple, but I can't seem to get my head around it today. What I'm fixing to do is to be able to control a motor from...
21
7,488
Hi, I have a 1500 that controls a station with diferents warehouses, but i also have a 1200 that controls one of those warehouses, i have been...
277
I have a Type C to RS485 adapter connect to my Siemens RWF55. I use modscan to scan it to get a value from the Siemens controller. In the...
102
