rslogix 5000 new instructions show on left
gerberz
Jan 2017
Midwest USA
26
rslogix 5000. New instructions show on left of the where i am currently selected.
So if I make a new branch then use the toolbar to create a XIO then use the toolbar to also create a OTE the OTE will be on the left side of the XIO.
When programming i think left to right not right to left so i end up always having to change things around. Is there a setting to change this?
I don't know if there is a more obvious way to make this change, but here is one way: at the bottom of the editor window you will see "INS" in a small box. Right-click in that box and select Append Mode, which will change it to "APP". This will make rung additions go to the right of the currently selected item. It appears that ctrl+I is also keyboard shortcut to switch between insert and append modes.
A few weeks ago I was testing out shortcuts I must have hit ctrl+I lol. That was driving me nuts Thanks!
Hello everyone! I am working on an existing system that contains a 1756-L73 controller, a 1756-DNB DeviceNet bridge, and a 2711-K3A5L1 PanelView...
2,783
I would like some guidance or a way to add SCL or SCP instructions to my Add-On I am using RS-Logix 5000
2,218
This should be a simple one. I'm trying to use a boolean value in a CPT instruction to either add a value or not. This is the statement...
6,379
I am converting a program from RSLogix 500 to 5000 in order to upgrade from SLC 5/04 to CompactLogix. From all of the information I can find, IIM...
3,110
Hi, My boss just ask me to convert all add on instructions into normal rungs. Currently, it is add ons in add ons.......... I am just wondering...
2,559
