Are IIM instructions obsolete in RSLogix 5000?
ezbz
Feb 2015
Washington
I am converting a program from RSLogix 500 to 5000 in order to upgrade from SLC 5/04 to CompactLogix. From all of the information I can find, IIM instructions are almost completely unnecessary with newer controllers due to improvements in technology and scan speed in particular. Can anyone tell me when this might NOT be the case?
:site:
The choice has been made for you, there is no Immediate Input instruction in Logix5000.
Input data is updated into the input tags at the input modules' selected RPI rate.
This means that input data can change state duri9ng the program scan (asynchronous I/O), which, under certain circumstances, can cause issues with programs converted from PLC5/SLC platforms that had synchronous I/O.
99% of the time this does not matter, but could be an issue that might need resolving.
Good Morning, I came across a new instruction and would like some help better understanding how it works. I am trying to add a new 24vdc input...
1,304
I am converting an older SLC program to a CompactLogix and I have run into a few instructions that aren't supported in CLX. INT (I/O Interupt)...
2,751
Hello, I have a machine that is counting plates and stacking them. I've found that when the gap is too small, the PLC gets the wrong count. Each...
1,853
I'm am trying to upgrade a machine from SLC to CompactLogix. In the SLC program, there is one subroutine that starts with an INT instruction...
3,010
I need help with IIM on a microligix 1500 with expansion I/O I have a analog expansion card that needs to be scanned firs but when i address the...
2,209
