Running View.exe in iFIX 5.9
DHoward
Jul 2012
South Carolina
25
I have a system to upgrade (Proficy iFIX v5.5 to 5.9) The graphics are not .grf files and are apparently opened using view.exe. Where can you get info on this older executable and download it so it can be executed in the startup tasks?
Thanks in advance for any advice
view.exe is part of Fix32, I don't recall it being present w/ the newer iFix systems at all. I presume your graphics files are .odf then?
View.exe was available until iFIX 5.5 as part of FIX Desktop option for iFIX, that allowed to run old FIX32 pictures on iFIX without having to upgrade then. Since iFIX 5.8 it is not supported anymore (http://help.geautomation.com/iFIX58/Subsystems/CM/content/cm_fix_desktop_folder.htm).
You can use the Migration Toolkit to upgrade the pictures to iFIX grf file (it's available on the iFIX installation DVD at ":\Setup\GE\MigrationTools". It's not just click and convert, but it's easier than redraw the pictures.
Hi all, I have a 2711R-T7T running an application without a shutdown button in the current program. I've looked at all the manuals and can not...
1,278
View SE Macros am I right? Yuck! It's a local app on an old 2003 terminal server. Can you run Macro scripts so they don't fill up the log? Can...
1,799
I'm sure there are some protections on this, but I want to start moving some projects to Advanced HMI (not sure of all the limitations). I'm...
2,227
Has anyone tried upgrading FactoryTalk View SE distributed while the system is running? We have a redundant system with a Primary Server...
2,457
I am using rsview 32 works 1500 . it was running good in running it shows error "microsoft visual C++ runtime library " what is this error ...
1,501
