CompactLogix -Fastest Datalog rate to SD Card
skyfox
Nov 2006
CA
279
1769-L24ER-QB1B CPU / RsLogix 5k V20
Does anyone know the fastest rate data (Float Register data) can be log to the SD card? Can it be done at 10ms intervals?
I don't know the answer, but I can't think why it couldn't, the hardware (SD transfer rate) is fast enough.
It's been a while since I looked at data-logging to SD, but seem to remember the sample-code routines were "verbose", but worked.
Is this a continuous log-file, or one that is periodic (comes in bursts). If it is periodic, you can always buffer the data in the PLC and write to SD at your leisure.
Hello, I have a panelview plus that reads from 4 different PLC's. 2 of these used to be Micrologix PLC's and someone else went and updated them to...
120
Hi All, I'm just trying to understand the reason behind something I recently experienced. Background: The system contains 4 CompactLogix...
165
326
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
194
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
136
