plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 5th, 2017, 10:35 AM   #1
IdealDan
Malaysia
IdealDan is offline
MIGRATING PROJECT FROM PANELBUILDER32 TO FT ME v9
Hi experienced Friends!
How can I migrate a project from Panel Builder32 to Factory Talk ME version 9 and make necessary corrections on the scripts?
I'll appreciate your inputs!
Old December 5th, 2017, 12:07 PM   #2
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
http://www.plctalk.net/qanda/showthread.php?t=93915
http://www.plctalk.net/qanda/showthread.php?t=64301
http://www.plctalk.net/qanda/showthread.php?t=63782
The above threads may help you out.
Regards,
__________________
Garry
https://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Old December 5th, 2017, 12:33 PM   #3
IdealDan
Malaysia
IdealDan is offline
Nice response, I do appreciate!
How can I switch arrays from BIT_ARRAYS to INT please?
Old December 5th, 2017, 12:42 PM   #4
gclshortt
Canada
gclshortt's Avatar
First link in list above will show how to switch arrays from BIT_ARRAYS to INT.
Regards,
__________________
Garry
Old December 6th, 2017, 06:10 AM   #5
IdealDan
Malaysia
IdealDan is offline
Regards,
Thanks, I will try it and reply. It seems there is no other way except by downloading Tag Conversion Tool?
Old December 6th, 2017, 01:19 PM   #6
arlenjacobs
Canada
arlenjacobs is offline
Quote:
You don't need to use the tag convert wizard.
That's only if you want to change from HMI tags over to direct reference tags; that's not required.
Old December 7th, 2017, 02:18 AM   #7
IdealDan
Malaysia
IdealDan is offline
Friends, I've gone through the Migration pdf Guide BUT still not cleared on procedures for some of the error corrrections, Please I need assistance as I'm stuck right now. STEP BY STEP GUIDE WILL HELP PLEASE. THANKS IN ADVANCE:
1. Tag es temp: Bit Array tags are not supported. Tag will be converted as a memory tag.
RECOMMENDATION ON MIGRATION GUIDE: Change the tag address to a full word address.
WHAT PROCEDURE PLEASE?
2. Screen 2 - GENERAL VIEW: Message display object will be converted to Multistate Indicator object at (224, 88).
RECOMMENDATION ON MIGRATION GUIDE: Message display object in PB32 is same as Multistate Indicator in FT.
WHAT SHOULD I DO PLEASE?
3. Bit and LSBit triggered alarms that used a Trigger Tag with a Bit data type will only be able to trigger a single alarm after import. WHAT SHOULD I DO PLEASE?
4. Alarm message Ack option not supported.
5. Blinking color images are not supported.
FT does not support Blinking colour image.
6.Tag pt502: The maximum value for this tag was invalid and has been set to the maximum valid value based on the tag's data type.
RECOMMENDATION ON MIGRATION GUIDE: Verify that the tag data type and maximum value are correct HOW?
7. Screen 3 - 82PK961A_B: Print flag for multistate indicator or message display at (257, 323) not supported.
I'LL BE GRATEFUL FOR YOUR HELP
Old December 7th, 2017, 11:54 AM   #8
arlenjacobs
Canada
My honest, best advice is that you should hire another person to migrate the project for you.
In the least, each of your questions should be their own post.
If you have a lot of those old PanelViews that need to migrate to FT ME v9, then you need learn and figure this out. There is no best (nor single) answer to your questions.
It matters on your project and what the original designer intended to happen.
Work through 1 issue at a time:
(a) Look at the project in PB32, the specific feature or object
(b) Read the help files on that object and how it works, based on how it was configured
(c) Look at the migrated project in FTV ME, same feature or object
(d) Read the help files and user manual to understand how it works for that feature/object.
Old December 10th, 2017, 06:18 PM   #9
IdealDan
Malaysia
IdealDan is offline
thanks
Old December 11th, 2017, 05:32 AM   #10
travispedley
United States
travispedley is offline
Migrating, in my opinion, sucks. The graphics it uses are terrible and the fonts are too. Makes your brand new beautiful PVPlus look like garbage. Just go through each page in your PV and recreate in PVP using modern buttons and objects. Make it look like it was designed to run on a PVP. Just my two cents. Good Luck.
Old December 11th, 2017, 05:45 AM   #11
IdealDan
Malaysia
IdealDan is offline
Quote:
Thanks Dear
Old December 11th, 2017, 12:56 PM   #12
IdealDan
Malaysia
IdealDan is offline
Thanks for your support Bro! and I believe I'm progressing now.
Just confirm this for me please:
On this error: Bit Array tags are not supported. Tag will be converted as a memory tag.
WHAT I DID: In Factory Talk, I opened Tag Dialog Box then under 'DATA TYPE' I choosed INTEGER. Is this correct?
Old December 12th, 2017, 01:21 PM   #13
arlenjacobs
Canada
Yes, that's the first step.
Next step is to look at the tag in PanelBuilder and see how it was setup: Ex. exactly which bits was it looking at? How many bits?
Just like Gary said before, take at look at this post for more detail on changing the bit arrays
Old December 12th, 2017, 11:05 PM   #14
IdealDan
Malaysia
IdealDan is offline
You've really been helpful,
Please I'm trying to open that example BIT ARRAY XML file in that link to have a full understanding but I'm having challenge, How do I open it/which Application?
Old December 12th, 2017, 11:18 PM   #15
IdealDan
Malaysia
IdealDan is offline
OK, I opened it with excel
In that example were you actually saying: state0=value0, state1=value1, state2=value2, state3 should be of value4?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Citect Vs WinCC - Long Doug_Adam LIVE PLC Questions And Answers 22 October 3rd, 2014 12:56 PM
How Can We Edit The Project Of Rsview Me siva_maddala LIVE PLC Questions And Answers 7 April 4th, 2007 04:22 AM
WinCC project reading STEP 7 project symbol table Pandiani LIVE PLC Questions And Answers 1 August 11th, 2005 03:20 PM
Funny effects when uploading project to S7 300 CPU RMA LIVE PLC Questions And Answers 9 October 28th, 2004 07:44 AM
Senior Design Project Suggestions...... Justin Lane LIVE PLC Questions And Answers 10 September 19th, 2003 11:03 AM
