Migrating FTV ME Alarms into SE
tsalheiser
Oct 2008
AL
We are upgrading our FTV ME v8.1 program to SE v12. Is there any way to migrate the alarm tags (about 600ish) from ME to SE. The import / export feature keeps throwing me errors. I assume it is a compatibility issue. Many thanks for your help.
The ME > SE alarm structure is completely different.
My advice would be, open your SE project, create 3-4 alarms manually, and export to excel. That will give you the format.
Then export your ME alarms to excel, and manually copy/paste/manipulate them into the required structure to be able to re-import them into the SE project.
The biggest catch is that in SE, it's not just a case of "this alarm has these parameters and this message". You have a list of alarms, and a list of messages. Then you have to match the alarms to the messages by number. It's unnecessarily complicated, IMO, but not insurmountable - once you have a working example (your exported SE file with a few alarms in it) you should be able to see what I mean and work it through.
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
50
Can it easily be done ? We have a legacy project written on Allen Bradly 1746-l542 with Several racks of some on an extension rack and some on A...
1,750
I just want to get others thoughts on what is the biggest obstacle one faces in migrating to a newer system? For me with the few systems I have...
17
4,125
Hi all, I'm working on migrating some old Sinamics S120 drive units currently integrated in Step 7 5.6/WinCC Flexible 2008 RT to TIA Portal V14...
3,394
Hi all, Has anyone here ever converted Wonderware tag history and added it to ignition's historical database? If so, how did you do it? Are...
2,412
