plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 6th, 2017, 04:50 PM   #1
nickegeson
Sweden
nickegeson is offline
Angry Connect PC to Kloeckner Moeller PS316
Dear forum,
Is there anyone out there with some experience from old Kloeckner Moeller PLCs?
I am in need of connect to a SUCOS PS316 and I have found out that I need the original non compiled program code which I have, the programming software ms-dos based Sucosoft S30 and a converter cable from rs232 and rs485 original from kloeckner moeller (UM 1.5-1). I have used both a new computer with VMware and windows 98 and also an old IBM computer with original win98 installed. What I found out is that you need to use 9600 baud rate, no parity, 8 bits and 1 stop bit, xon/xoff OFF.
The problem is that I do not succeed to connect. Every attempt I do I just get “DATA TRANSFER ERROR”. I have also tried different settings for baudrate and parity plus direct rs 232 cable without any luck. I made the settings both in windows and also with mode command in ms-dos. What I can see there is no possible settings to be done in the programming software more than choose correct com port.
Anyone have any experience from this old system and have an idea what I am missing and/or doing wrong?
Thanks in advance!
Old December 7th, 2017, 08:52 AM   #2
shooter
Netherlands
shooter is offline
shooter's Avatar
please check if computer has flow control with old DTS/DTR, meaning the wires on 4,6,7 must be in place.
__________________
shooter@home.nl
skype shooter paul.deelen
Computer Shooter
Paul Deelen
J. Wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
+31653300739
Old December 17th, 2017, 05:22 AM   #3
nickegeson
Sweden
Thanks for your input.
I suceeded by using com port configuration dos command mode by setting "mode com1: 9600,n,8,1,p". The "p" seemed to have been the problem which means if I understand correct "xon/xoff" on. Using windows 98 device manager to set did by some reason not work. Another problem is that I did not succeed using VMWare player with windows 98. Even if you could see some kind of communication by watching the led on the serial port adapter it would not connect with the PLC. However using the old windows 98 computer with built in serial port the communication worked directly with the setting mentioned above.
Finally I tried using Virtualbox with windows 98. I did not want to rely on the old computer so I really wanted the virtual environment on the new computer to work with the PLC. With virtualbox it worked very well to communicate with the PLC using the same parameters as above.
Old December 18th, 2017, 01:52 PM   #4
shooter
Netherlands
shooter is offline
shooter's Avatar
yes xon/xoff is flow control, so it will stop sending bits when this byte is received, RTS is hardware and Xon is software control.
Newer computers ( and these dongle types do not have hardware control. so
__________________
shooter@home.nl
Computer Shooter
Paul Deelen
+31653300739
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
I can't connect Siemens s7 200 with pc using serial to usb converter Solm86 LIVE PLC Questions And Answers 11 November 13th, 2017 08:12 AM
How to connect Domino A200 inkjet printer to PC TKADA LIVE PLC Questions And Answers 3 November 10th, 2014 04:38 AM
Schematic to Connect PC to S7 200 aluis LIVE PLC Questions And Answers 0 September 20th, 2014 09:38 AM
Setting up CP 343-1 card (siemens) Johnny T LIVE PLC Questions And Answers 35 August 19th, 2005 06:58 AM
connect s7 to wincc with pc adaptor? mansoreh LIVE PLC Questions And Answers 8 October 7th, 2004 09:07 AM
