Wonderare OPCLink w/ RSLinx OPC Server
phuz
Jun 2008
Mohnton, PA
1,044
I've given up on the FSGateway because it just doesn't want to create a connection (continuous errors in logger about OPCEnum), so I decided to try OPCLink. I configured it for the remote node with RSLinx Remote OPC Server and added my suitelink object to point at it. And, sure enough OPC Link shows a connection and RSLinx (on the remote end) shows the connection, too.
But, I can't get my items to parse properly. I've tried putting the OPC qualifier in front of the tag, but no dice.
107690 12/14/2017 10:18:11 AM 3892 5048 Info OPCLink Invalid item name: C5:7.ACC (IMPULSE)
107691 12/14/2017 10:18:11 AM 3892 5048 Info OPCLink Invalid item name: [IMPULSE]C5:0.ACC (IMPULSE)
Any ideas?
I don't understand the "OPC Path" either, so maybe that's part of it.
You could try using the OPC Test Client (under RS-Linx->Tools) to connect to the data item in question. That tool will build the Item string that should be compatible with other OPC-compatible clients.
Assuming "IMPULSE" is the OPC topic defined on the local machine, the second address looks good. However, if it is defined remotely, and you are using RS-Linx Professional (or whatever they call it now), there may also need to be a node name preceding the topic along with "::".
OPC client sees the data fine, and the string is exactly what I thought it would be:
[IMPULSE]C5:0.ACC
Whether I put [IMPULSE] in the OPCLink for the "OPC Path" or not, I still get this:
109066 12/14/2017 11:13:18 AM 3892 5048 Info OPCLink Invalid item name: C5:0.ACC (RSLINXOPC)
109069 12/14/2017 11:13:18 AM 3892 5048 Info OPCLink Invalid item name: [IMPULSE]C5:0.ACC (RSLINXOPC)
Holy stars...just found the answer hidden in a forum post on here from 2011.
I would have never found this otherwise:
One of the big "gotcha's" with OPCLink (might want to investigate using FSGateway BTW) is you have to put a prefix in front of the Item in the tagname definition.
d - for discrete
i - for integer
r - for real
m - for message
So my config was right all along. Just had to modify the input string:
Me.IMP_A_Gallons.inputsource = "PLC5_IMPULSE.IMPULSE.iC5:7.ACC";
hi dears : I'm working at intouch wonderware ...... I want install intouch at new PC ..... but I don't have software ( intouch and OPCLink )...
1,718
Hello. What I have : 1. Windows 7 2. OPC server (TwinCAT) 3. OPClink 8.0 (Wonderware) I configured opclink and locally can see items of...
1,568
I am using WW 9.5, opclink 8.0, and trying to read data from Matrikons S7 server(MPI link). I read data ok when using Matrikon simulator but when...
2,813
Hi, I am having RSLinx Gateway and WodnerWare Intouch 10.0. I want to connect ControlLogix L63 processor with Ethernet IP(1756-ENBT) to...
18
35,291
I'm just getting my feet wet with getting OPC data into Intouch 9.5. I've set up OPCLink with a few test tags coming from a couple of OPC servers...
24,104
