Wonderware InTouch 9.5,opclink,matrikon
robvanfrank
Apr 2012
Ohio
I am using WW 9.5, opclink 8.0, and trying to read data from Matrikons S7 server(MPI link). I read data ok when using Matrikon simulator but when using live server all tags error out. It appears that the syntax is different in the server as compared to simulator. Simulator syntax is with (.) as delimiter and the live server ues (>) as delimiter. It doesn't look like OPClink is able to understand this syntax. Also I am wondering about the ITEM syntax in the InTouch tag database. I have seen so many differnt ways recently I have no idea which is correct. Thanking anyone in advance if they can shed some light.o_O
Is there a particular reason you're using 9.5 and haven't upgraded to 10.5? I'd strongly recommend this. OPCLink becomes redundant and its functionality is built directly into Factory Suite Gateway. I recently did a conversion from OPCLink to FSGateway and while I did have to rebuild my whole tag database as the naming was slightly different, it was a lot easier to work with afterwards.
we are using Schneider's OFS Large, i'm not familiar with Matrikon's offering.
Hi, I am having RSLinx Gateway and WodnerWare Intouch 10.0. I want to connect ControlLogix L63 processor with Ethernet IP(1756-ENBT) to...
18
35,313
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
149
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
162
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
417
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
190
