Wonderware InTouch v11.1 tag definition OPC UA
xavisole125
Apr 2016
banbury
Hi all,
I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the OI.GATEWAY.2 server but I am unable to access those tags from the InTouch standalone application. I understand application names and access names are not used using an OPC UA.
Which structure does the Item name from the tag name dictionary needs to have to connect to the OPC server in a standalone application?
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
149
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
158
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
412
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
481
Hi guys. I am using Intouch Wonderware. Does anyone know how to enlarge the AlarmViewerCtrl properties window? In my case it is cut off as in the...
1,496
